Need help about VPNCmd
Collector
Post by Collector » Thu Apr 23, 2020 3:22 pm
Hi!
I'd like to use the command line to manage Online/Offline Cascade Connections on a remote Virtual Hub.
I can normally access such Hub using the Softether GUI, but I cannot find the correct syntax for the command line.
Could some experienced user show me some working examples?
Thank you in advance.
sky59
Re: Need help about VPNCmd
Post by sky59 » Thu Apr 23, 2020 4:54 pm
it is not just one command
it also depends what you want, the only way is to read help and "try and see"
