Hi guys! Who can help me?
Have SE-VPN Server on PC1 (win10) with white IP (single network card), all ports work. Connecting from PC2 (win10) via SE SSL-VPN Protocol.
How do I configure the Server and the Client to access PC1 files?
How to setup SE-VPN Server on PC with white IP?
Re: How to setup SE-VPN Server on PC with white IP?
Answer:
If you install a VPN client on PC1 and connect to your Virtual HUB, you can communicate with PC2.
Assign the same segment IP address to the virtual LAN cards of PC1 and PC2.
Access PC1 with the assigned address.
(big thanx to cedar for answer on japanese forum!!!)
