I follow each of this tutoriel for install and connect softether client to vpn server host on vpn gate :
https://medium.com/@anuradha.15/install ... a405a0ae2c
but after many try, it always happen trouble when i set dhclient for my adapater... none ipv4 assigned.
i have try to change server,cut my firewall router,foward port tcp then udp, nothing.
However i can ping this server, and the vpn client is connect on server :
https://zupimages.net/viewer.php?id=20/18/xq96.png
https://zupimages.net/viewer.php?id=20/18/ivs4.png
Maybe a problem when i describe virtual hub?
For, exemple with the server 5.181.235.122 i had set for virtual hub "vpn326279540.opengw.net"
Thank you !
Zenvice
dhclient can't work ?
Re: dhclient can't work ?
I think I have the same issue: https://www.vpnusers.com/viewtopic.php?f=7&t=65526
What does this command give you?
In my case I see always vpn interface unknown..
But for many days I use the vpn worked correctly; I didn't change any config
If I do ip monitor all, It give me this
ip -br link show
# ip monitor all
[NEIGH]fe80::2ae:4dff:fe00:ae4d dev vpn_vpn2 lladdr 00:ae:4d:12:8f:74 PROBE
[NEIGH]fe80::2ae:4dff:fe00:ae4d dev vpn_vpn2 FAILED
[NEIGH]fe80::2ae:4dff:fe00:ae4d dev vpn_vpn2 lladdr 00:ae:4d:12:8f:74 STALE
