user name & password requirement
paulpaffett
Post by paulpaffett » Tue May 05, 2020 9:51 am
I am trying to find a way to set the SoftEther client to ALWAYS require the user to enter a user name & password. Thanks.
centeredki69
Re: user name & password requirement
Post by centeredki69 » Tue May 05, 2020 11:09 am
There is an option to require password but not username & password.
SE-server manager > manage Virtual HUB > Manage Users > highlight user and EDIT or create NEW user > CHECK set security policy > enable "Disallow password save in VPN client" Security policies can also be set under Groups.
Note: After the policy is set on the SE-Server the VPN Client will be able to connect one more time without manually entering the password . During this connection the SE-server will send the policy to the VPN client. Any further connections will require a manual password entry. I also found it only works on the SE-VPN client. Native Windows and Mobile VPN clients seem to still connect without a manual entry.
