Hi ,
How can I configure the VPN Server with SecureNAT without DHCP Server Enabled and to assign a static network IP address to each user? Please advise if and how this can be done, to limit each user to a single fixed IP.
Thank you in advance.
Steven
VPN Server with Secure NAT without DHCP Server enabled
Re: VPN Server with Secure NAT without DHCP Server enabled
Hi Steven,
the only way you have to do this, is to assign a static IP in the client´s network card.
And really you don´t need to active Secure NAT, when you this don´t need.
Regards
Sandro
Regards
Sandro
Maybe you could make another machine with your preferred DHCP server that connects as a client to the securenat and would answer to DHCP querries. I don't remember if each securenat client can talk to each other or if they can only talk to the server.
I haven't tested this, but if it can inspire you
