Get OpenVPN Config File
I have a server on Ubuntu 18.04, how to get the config file for Openvpn? Like on Windows which you can generate it with one click. Thanks
Re: Get OpenVPN Config File
Connect windows machine to ubuntu and click...
Yes you probably need to connect using a windows machine via softether server manager (tool) to the ubuntu server and generate it. I don't know if there is a similar function using vpncmd, you'd have to check the commands
