Access to internet question
christ2000
Post by christ2000 » Thu May 14, 2020 1:49 am
Hello, first to offer this great software for free.
In install and connect my client to client to server vpn and work fine, but now i notice this:
My internet speed in client is slow when i connect to server vpn, also i notice that if i check my internet ip, thi show the remote ip and not my local internet ip. so i think for this reason my internet access is using the remote access on the vpn server and for this reason is slower.
Is there any way to use my local internet to surf on internet and not the remote internet access on the server, so use the virtual adapter just for access the data on my vpn server?
thanks
ziddey
Re: Access to internet question
Post by ziddey » Thu May 14, 2020 7:53 am
Check No Adjustments of Routing Table
christ2000
Post by christ2000 » Thu May 14, 2020 2:39 pm
Thanks, i also notice i must put default gateway in network connection, if not do no work
thanks
