Lots of random connections
osandercock
Post by osandercock » Thu May 14, 2020 11:48 am
I'm getting issues with my SE server. Looking through the Server_log_vpn and i can see loads of these entries:
2020-05-14 12:32:22.975 On the TCP Listener (Port 5555), a Client (IP address 172.16.0.1, Host name "172.16.0.1", Port number 53524) has connected.
2020-05-14 12:32:22.975 For the client (IP address: 172.16.0.1, host name: "172.16.0.1", port number: 53524), connection "CID-1309" has been created.
2020-05-14 12:32:23.022 SSL communication for connection "CID-1309" has been started. The encryption algorithm name is "TLS_AES_256_GCM_SHA384".
2020-05-14 12:32:23.068 Connection "CID-1309" has been terminated.
I only have 30 users, i can see when they connect as they show as their own CID.
172.16.0.1 is my firewall/gateway.
Any ideas?
Thanks
drkrool
Re: Lots of random connections
Post by drkrool » Thu May 28, 2020 11:26 am
Maybe it's the "keep alive" feature as it seem to be very brief. I don't know for sure, just throwing this idea
ziddey
Post by ziddey » Thu May 28, 2020 9:22 pm
nah, keepalive is outbound to port 80 by default.
not sure of your gateway setup, but generally, you'd end up seeing the gateway's internal ip for NAT loopback, ie you have a device in your LAN attempting to connect to softether via the WAN IP (and of course have appropriate port forwarding).
if it's coming from the internet, you'd see the actual source ip and not your gateway's.
you can watch the network (tcpdump/wireshark) to find the source
