Hi, We have an operational vpn server with several windows client all using the softether client. the server is making use of the DDNS and NAT-T functions and we have nothing set up on our firewall. All is OK.
We now need to allow a copy of mac users to connect. I have enabled LT2P on the server, but nothing can connect to this, it just times out (mac or windows). should this work through DDNS and NAT-T?
Also I know the there is a mac client, but it is command line, but i can not find any instructions on how to configure this, can any one point me in the right direction?
Many Thanks
LT2P via DDNS and NAT-T
centeredki69
Re: LT2P via DDNS and NAT-T
L2TP/IPsec requires that you open/ forward ports UDP 500 & UDP 4500 to the SE server host. Also you would need to activate the L2TP/IPsec feature on the SE server. See Link for setup. Port info is at bottom of the page
https://www.softether.org/4-docs/2-howt ... VPN_Server
peted
We are unable to use port forwarding, we are behind a managed firewall/router, and if we set up port forwarding, the ISP says we have to specify a source IP. As these is for remote access, this will be different most of the time. So Port forward is out of the question.
So i need to know how we can enable macs access through the NAT-T Feature.
Any Advice would be great.
centeredki69
You could try the MAC client although SE themselves recommends you do not use it. I have no knowledge of how to implement it. However, one solution you could use is to install another "SE-SERVER" at a second location ie. house, 2nd office or even be a cloud hosted VM. The location of course would need to have the ability to open/forward the proper L2TP/IPsec ports. The "office" SE-Server would make and maintain an outbound "cascade connection" to the "offsite" location. The MAC clients would connect to the "offsite" SE-server and have access to the Office through the "cascade connection".
fordmurphy
I am unable to use port forwarding...
drkrool
I'm not quite sure this would be a reliable solution if you are talking about doing this in a buisness.
Is the port issue with the firewall only on port 500 or can any other port be opened?
