I can't connect via lte to softether-server. If I go via WLAN / WIFI it works. Any suggestions to fix this problem?
Thanks
Hubert
no connection via lte
drkrool
Re: no connection via lte
Maybe your LTE provider is blocking some ports. It depends on what device and what protocol on what port. If you are on android, try openvpn using tcp on port 443. it's usually allowed. On PC, try the softether client on port 443, this last one is https so it's undistinguishable from any other website connection
