Hello. I have been using softether for some time without problems. And I thank the developers for this extraordinary software. However, the azure vpn connection no longer works (but L2tp doesn't seem to work either). The certificate from the local server side, as far as I can understand, is valid (2037-12-31) (see photo). Is there any problem on the softether servers or is there anything I can do? Someone can help me?
Thank You
dept: 3 error: certificate has expired (10)
aantonio
aantonio
Re: dept: 3 error: certificate has expired (10)
Someone can help me about how renew the certificate?
Thank's
Thank's
zploz
I have the same issue. Appreciate any one has solution on this.
I am using a client in Andriod phone
zploz
This should be related to Addtrust CA cert expiry.
https://www.ssl.com/blogs/addtrust-exte ... y-30-2020/
aantonio
Then? Is there something can we do? Have the CA root to be replaced on the softether global server by the owners?
aantonio
Resolved, changing vpn client with an updated one
zploz
Windows 7 or Windows 10 sstp works. But not on andriod phone.
Check it out the server address via ssl checker
https://www.sslshopper.com/ssl-checker.html
It shows few CA certs are expired and going to expire soon
zploz
Could developer update the cert?
The cert expired is related to all *.vpnazure.net site
