Hello everyone,
I am trying to get my Android phone to connect to my SoftEther VPN server.
It works without any issues with Windows, but fails no matter what I try in Android.
Which settings must I set on the server and how do I configure my Android phone?
The help/website does not go into any real details and the things that are stated do not work. Has someone created e.g. an OpenVPN profile and knows how to do so?
I have now even created server and user certificates and still can't get it to run. There must a simple solution to this.
My internet provider, by the way, only uses DS-Lite, so I can only be reached by IPv6.
Here is my config. Maybe someone can tell me what I set up wrongly or how I need to authenticate myself from Android?
Thank you in advance! I am really going crazy here :(
How can I configure Android with SoftEther VPN Server?
AleXSR700
AleXSR700
Re: How can I configure Android with SoftEther VPN Server?
deleted
aboka
how are you connecting on your android? am using OpenVPN Connect many years without issue.
here is how i setup - download and install the apps from Play Store then import the ovpn file and connect
AleXSR700
thank you for your reply, but I am giving up on SoftEther.
Unfortunately the capabilities seem great on paper but it is too, well, unreliable. I need a more reliable implementation of a VPN server that works with all devices equally well.
Not sure what will be my next step, but probably looking for a device with built in VPN capabilities.
Thank you all for your help though :)
