Hi
AFter the VPN connection is there any way to route the internet traffic from the machine itself not from VPN Server?
Please suggest me what to do.
Internet Traffic to go through client Machine not from VPN.
Re: Internet Traffic to go through client Machine not from VPN.
you should change metric at vpn interface (default 1)
bigger then mertic on you local (ethernet/wifi) interface. Then you vpn trafic goes to vpn connection and your internet trafic goes to you local interface.You do not have the required permissions to view the files attached to this post.
Thank you i changed value 1024 now interface changed and internet divert to client network
VPN Network Properties > TCP iP 4 Properties > Advance > metric value add 1024 now working.
Thank You
Mahesh Kadam
Thank You
Mahesh Kadam
