Forgive me if this has already been covered on another post, but I wanted to see if it is possible to use the builtin Windows VPN connection to connect to a server running the VPN server.
Essentially what my goal is, is to make it so when a computer boots to the user login screen I can make use of the VPN dialer available in Windows already.
At the moment if I attempt to use the Windows VPN connection I get this error: "The PPP link control protocol was terminated"
I've looked into this error a little bit but most of the information I found dealt with dial up connections and didn't seem to fit the context of my environment. So any help would be greatly appreciated!
Softether VPN Server and Windows VPN connection
tapp.tech
