Where is OpenVPN config? Slow login process
aboka
Post by aboka » Sun Jun 21, 2020 8:08 am
hi, I am on Ubuntu 20.04 LTS and running Softether v4.34-9745-beta. Would like to ask(since couldn't find it on google) where is OpenVPN config file?
Would like to change some configuration in there for eg. TAP to TUN. Bcoz if i setup the vpn using bridge, the first connection to the vpn server is slow. This only happens is i use OpenVPN and L2TP, but SE seems to be ok. it will pause at "'PUSH_REQUEST' (status=1)" few seconds for few times then only manage to connect. Everything is working after its connected. There will be no such issue if i set it up using SecureNAT
Which log file should i look into for this kind of connection issue?
1) /usr/local/vpnserver/server_log/
2) /usr/local/vpnserver/security_log/
p/s - anyway to change SE's log level for more details troubleshooting
thank you,
