Is my web history can be hidden from any parent agency like Government or orgamization by using VPN Gate?
karimkhanp
While I am using Internet, I will prefer that my organization or Goverment does not know the history of what websites I am accessing. Will it be achieved by using VPNGate?
drkrool
Re: Is my web history can be hidden from any parent agency like Government or orgamization by using VPN Gate?
It should, but I can't assure you that the DNS won't leak so maybe use a public dns like cloudflare or google or opendns
The traffic itself is pretty well encrypted. Use another country's vpn if you are affraid of your gov, but they could also run a node so you never know. I would trust it probably as much as TOR. If you are 1000% paranoid, use tor while connected to vpngate. Never 100% secure, but pretty good
