VPN Server PC
VPN Server PC
I want to install the VPN server on a PC in my local LAN. My question is simple, can someone be using that PC to do other work while the VPN server is running on it?
Re: VPN Server PC
Yes, absolutely. The only situation where you will notice it, is if VPN traffic becomes high enough to use most of the computer's bandwidth.
