"RetryInterval"maybe can be setting in SoftEther Server
sejuka
Post by sejuka » Sun Jun 28, 2020 9:43 am
the "RetryInterval" that appear in vpn_server.config can be setting by user in SoftEther Server. However,it not working when i change the RetryInterval. I found the question that not working when i get the source code.
// this code in module Cedar => Link.c ( 640 lines)
o->RetryInterval = 10;
the default RetryInterval time just 10 seconds, it's so short that the software allways be the connecting. So, i think the RetryInterval can be setting by user,and it 's meaningful.
Yes, it just a simple change like this:
o->RetryInterval = option->RetryInterval;
that's is my opinion.
