I have a VPN Server having "UDP Acceleration" enabled.
I have clients connecting to the server from different locations. There is one notebook that does not activate "UPD Acceleration". If i use it from another location it works.
Based on what choose the client to activate or not "UPD Acceleration" ?
Without "UPD Acceleration" a roundtrip is around 600 - 700 ms. With it is around 14-15 ms.
The laptop that does not use "UPD Acceleration" is behind a Mikrotik Hex S router.
What should I check ?
UDP Acceleration not active
drkrool
Re: UDP Acceleration not active
I would use it mostly on high latency connection, I believe it shouldn't make a big difference on most high-speed internet connection. But to be honest I can't say exactly what it does in detail
