No connection
LambdaEnt
No connection
Post by LambdaEnt » Tue Jul 07, 2020 7:26 pm
I am an IT consultant but new to SoftEther. I have setup the server on a remote Windows 10 machine. I can not connect from my home Mac. I have tried connecting via the softether and azure DDNS, as well as directly to the IP.
Attached are screen shots.
Thank you!
centeredki69
Re: No connection
Post by centeredki69 » Tue Jul 07, 2020 7:32 pm
Based on the images you posted I'm assuming you want to connect using L2tp/ IPsec. If so you will need to open/forward UDP ports 500 & 4500 to the SoftEther server Host (Win10 Machine) local IP address.
LambdaEnt
Re: No connection
Post by LambdaEnt » Wed Jul 08, 2020 1:41 am
That did it, thank you!!!
jax_mill
Re: No connection
Post by jax_mill » Thu Jul 09, 2020 2:12 pm
Based on the images you posted I'm assuming you want to connect using L2tp/ IPsec. If so you will need to open/forward UDP ports 500 & 4500 to the SoftEther server Host (Win10 Machine) local IPCOLOR=#EBEADC SIZE=5 coding homework help address.
I also have problem with connection and maybe you can help me as well, since installing some MS updates I cannot connect to VPNs using the Win10 built in client. OpenVPN, forticlient and nortel all work ok though.
A ping to a.root-servers.net which is successful and the connect screen showing that my connection to vodafone is up but the VPN Icons still show not available like I'm offline.
