Connect to remote MySQL Database
adcdao
Post by adcdao » Fri Jul 10, 2020 3:46 pm
Hello, is it possible to connect to a remote MySQL database through VPN? I have access to all files but trying to access the database I have an access denied error? If possible, may I have detailed instructions?
Regards,
André
drkrool
Re: Connect to remote MySQL Database
Post by drkrool » Fri Jul 31, 2020 2:18 am
Is the database on the same server as the softether's vpn (or same physical host if a vm)?
