Change SSTP port
kapollo
Change SSTP port
Post by kapollo » Fri Jul 10, 2020 8:58 pm
Is it possible to change the SSTP port from default 443 it collides with apache, and I'm wondering if it is at all possible?
BR
kapollo
Re: Change SSTP port
Post by kapollo » Fri Jul 10, 2020 10:53 pm
Ok I found it, it was ... enlightening, it's the same port as for the OpenVPN.
BR
drkrool
Post by drkrool » Fri Jul 31, 2020 2:15 am
Good that you found it. I personally use HAProxy to have multiple services on port 443 and selected via domain name (reverse proxy). Try it if you've got time, it's really great
