Understanding of Softether lan to lan bridge requirements
chuck12
Post by chuck12 » Mon Jul 13, 2020 1:29 am
Hi all,
I'm looking to get various devices from one lan accessible to and from another lan. Devices include ip cameras, ip printers/copiers and computers. Ip cameras and printers can't have additional client software installed.
I read the documentation but I may have missed it. It's my understanding that for each device on each lan, it is required the installation of the softether client software to connect to the vpn hub which then is communicated to the other vpn hubs/central server?
Thanks,
Chuck
centeredki69
Re: Understanding of Softether lan to lan bridge requirements
Post by centeredki69 » Tue Jul 14, 2020 10:45 pm
You do not need to install the client on all the devices to access them. The following links should give the info you are looking for.
https://www.softether.org/4-docs/2-howt ... Bridge_VPN
https://www.softether.org/4-docs/1-manu ... L2_Bridge)
https://www.softether.org/4-docs/1-manu ... P_Routing)
