How to change regen-sec value in Softether?
aboka
Post by aboka » Wed Jul 15, 2020 6:56 am
hi, hv setup Softether(v4.34-9745-beta-2020.04.05-linux-x64-64bit) on a Ubuntu. all works fine, but notice when connect using OpenVPN Connect on Android, it will disconnect and reconnects every hour. Search online and think its relate to the value regen-sec as its default value is 3600 exactly an hour
We could easily change that in the server config file if I am using OpenVPN server, but how do we do this with Softether? Read a post here that the value is hardcoded into SE, if thats true, what is the alternate solution to solve this?
Thank you,
drkrool
Re: How to change regen-sec value in Softether?
Post by drkrool » Mon Jul 27, 2020 3:08 pm
Would be interrested to know this as well (where, if possible, we can change simple openvpn server config)
