My VPN Server has been hacked
darwin.ranzone
Post by darwin.ranzone » Wed Jul 15, 2020 2:46 pm
Hi, My VPN Server has been hacked,
it seems the attacked taped into the OpenVPN module
I Could not determine exactly how he was able to get in
his login attempts do not show up in the user list, nor does his VPN Traffic
I have also enabled security logs but nothing from OpenVPN seemed to go there when he got in
i really wanted to know what user he used (if he even used one of the users)
I Was able to block his attack in my firewall but I was curious there seems they have an exploit they can use against the OpenVPN Module
I have also gathered all the logs to find out how this attacker is getting in
Any suggestions on how to find this out?
sky59
Re: My VPN Server has been hacked
Post by sky59 » Sat Jul 18, 2020 6:17 am
I made my server 100000000% resistant against any attack
I use orangepizero that uses SD card as system medium.
I installed everything i needed - se server
But i copy all during boot into /tmp folder that is in ram memory.
My SD card is PERMANENTLY LOCKED even i myself can not do anything about it
Yes, no more changes possible, only to change sd card with new code
If you want to be even more f*cking-off-possible-attackers you can use hardware watch based switch and, say, at 03:00 you can reboot your server by hardswitching off/on - no risk to damage sd card it is locked!
So if any attacker managed to install something into ram system at night it is gone! :) I am sure then it is not an interest of any attackers any more :-)
darwin.ranzone
Post by darwin.ranzone » Sat Jul 18, 2020 5:02 pm
Intetesting Ideas thanks for that
After further investigation i think i was not hacked, but i was definitely under attack
The Brute force attempt against my OpenVPN daemon cost me a few dozen gigabytes of traffic
but I have blocked everything now and it is all good
it turns out i was confudes about being hacked so false alarm!!
darwin.ranzone
Post by darwin.ranzone » Sat Jul 18, 2020 5:05 pm
After further investigation, it turns out I was not hacked
The brute force attempts to hack my server cost me a few dozen gigabytes of traffic tough
But as for the hacking, it seems it was a false alarm
Thanks for your tips on securing the VPN server
