get connected but then error messages
Don-Santo
Post by Don-Santo » Mon Jul 20, 2020 2:38 pm
Hi guys!
Former we had a Huawei Router at the remote company where we want connect to. For connecting we use HTTPS (also called HTTP over TLS, HTTP (Hypertext Transfer Protocol) over SSL = TLS.
Now a Fritz Box 6890 has been installed instead. The producer of the Fritz! Router wrote: “Unfortunately, we have to inform you that the FRITZ! Boxes can only use IP-Sec (IKE v1) and VPN-TLS connections are not supported.”
Does it mean we cannot use the SoftEther VPN client/server for connecting with TLS?
When we start the SoftEther client we get the informtion “Connected”. Then we start Windows “Remote desktop” and after that we get those message with(white cross on red ground):
1) Remote access on the server is not activated.
2) The remote computer is switched off.
3) The remote computer is not available on the network.
This is unbelivabel, because the Remot computer works and the remote access is activated!!
best regards Andi
centeredki69
Re: get connected but then error messages
Post by centeredki69 » Thu Jul 23, 2020 11:34 am
Does the Softether client computer display a pop up window that shows it received an IP Address? If not you need to create a "local Bridge" between the Virtual and the local network. This is done in the SE server manager.
https://www.softether.org/4-docs/1-manu ... al_Bridges
Don-Santo
Post by Don-Santo » Thu Jul 23, 2020 6:35 pm
Hi "centerdki69"
Many thanx for your answer. Yes, the Softether client computer does display the receive of an IP Address!
Don-Santo
Post by Don-Santo » Fri Jul 24, 2020 3:25 pm
Now problem ist solved. The Fritz Box can connect through all TLS-VPN requests. There was a need to open port 443 at the Fritz box 6890 router under the network items. Now it works. SofEther VPN solution works great!!
