Is it possible to connect two servers to each other?
AleXSR700
Post by AleXSR700 » Mon Jul 20, 2020 2:55 pm
as the client situation on both Linux and Android is a bit of a pain, I was wondering if it is possible to connect two servers to each other?
Setting up a server is pretty easy using the Windows server management tool. So could I use a server-to-server connection and have both networks be able to access each others LAN without having to install SoftEther clients and without having to set up ip route etc.?
sky59
Re: Is it possible to connect two servers to each other?
Post by sky59 » Mon Jul 20, 2020 3:16 pm
Yes, then one of the servers is called bridge
