how to use admin password for virtual hub?
truacaldwell
Post by truacaldwell » Wed Jul 29, 2020 8:29 am
Hello, I assigned a password for a virtual hub, when I login to the vpn server manager and click on that virtual hub. It doesn't prompt me the password and can be enter the hub directly. I would like to know how to use this password?
centeredki69
Re: how to use admin password for virtual hub?
Post by centeredki69 » Wed Jul 29, 2020 11:12 am
The Server Admin has control and access to everything on the Server. This allows them to create, control, fix, reset all settings on the server. ( like when the HUB admin forgets their password).
Create a HUB & set the "HUB Admin" password to SOMETHING DIFFERENT then the "Server Admin" password. Now on the "server manager" main screen ( this would most likely be done on the HUB Administrators computer). Add a new setting. On the right side of the popup choose "Virtual HUB Admin Mode" and choose the HUB from the drop down menu. Enter the HUB Admin Password.
If the HUB admin Person tries to access the server by choosing the "Server Admin mode" instead of "Virtual HUB Admin Mode" they will be blocked as the passwords are different.
