vpn client connecting
jhshim
Post by jhshim » Fri Jul 31, 2020 7:14 am
I install vpnclient on aws(ubuntu 18.04) and try to connect server.
but it's status not changing 'Connecting'
(vpnserver was installed on azure)
Thanks for read
sky59
Re: vpn client connecting
Post by sky59 » Fri Jul 31, 2020 8:38 am
The printscreen is from vpncmd?
jhshim
Post by jhshim » Fri Jul 31, 2020 8:48 am
@sky59
Thanks for reply
yes I capture on vpncmd
