SoftEther server setup for L2TP and openvpn
poijku
Post by poijku » Fri Jul 31, 2020 2:32 pm
Hi everyone,
I have setup a softether server in a VPS using Microsoft Azure. I can connect to it using softether client. I have also setup the server for L2TP and openvpn but when I try to connect to the server using any of these, the connection fails. Do I need to open some ports on the vps? The error message on windows (When I try to connect using L2TP) is "L2TP connection failed because the security layer encountered a processing error during the initial negotiations with the remote computer". On the android device, I get a error saying connection unsuccessful.
I have made sure that the shared key is same but still I am getting an error. Please help, I was not able to get clear answers anywhere.
sethash
Re: SoftEther server setup for L2TP and openvpn
Post by sethash » Fri Jul 31, 2020 8:57 pm
Hey mate,
For L2TP to work, you should also forward 500, 1701 and 4500 in your modem.
Try this and let me know how you go.
Cheers
sethash
Post by sethash » Fri Jul 31, 2020 10:34 pm
For OpenVPN, you should forward the port defined in you setting. Default is 1194.
poijku
Post by poijku » Sat Aug 01, 2020 8:03 am
Hey mate,
Cheers
The vpn server is on a VPS in the cloud so the appropriate settings must be made for that? As for forwarding 500, 1701 and 4500 goes, how do I do that? Please explain (I am a noob at this doing this for personal use)
sethash
Post by sethash » Sat Aug 01, 2020 8:25 am
All these setting should be done in your local router under port forwarding.
