Hi
I have a server running a Softether VPN server on it.
I also have two clients connected to the server. I am trying to stream Udp Multicast packets between the two clients. The issue is every time the packet reaches over around 30packets/second the stream stops. Is there some sort of Udp flooding or DOS protection that can be disabled to allow this stream to happen?
Regards
Jack
Udp Multicast Issue
Re: Udp Multicast Issue
we have tried TS over UDP multicast video stream, and it works well, even for 4k.
do you use wifi between the connections? it seems wifi has limitation for multicast.
With your
I was using wifi on one of the devices. I will try connecting them both via ethernet. Did you have any issues with DOS protection?
Were you using NDI for that video stream?
Regards
Jack
Hi, Thanks for your reply.xiaowei.zhang wrote: ↑Sun Aug 16, 2020 2:28 pmwe have tried TS over UDP multicast video stream, and it works well, even for 4k.
Regards
Jack
