RDP connection to VPS drops when connecting to VPN
Gerard1
Post by Gerard1 » Mon Sep 07, 2020 5:10 pm
Guys, i have virtual server Windows 2012. I need connect from RDP machine to VPN. The connection succeeds, but since the VPS gets a new IP, the existing RDP connection is dropped.
Only reboot rdp machine help me.
VPN server is SE VPN Ubuntu 16.04.
How can i connect to VPN without lost rdp connection?
ethanolson
Re: RDP connection to VPS drops when connecting to VPN
Post by ethanolson » Tue Sep 08, 2020 4:17 am
Split Tunnel is probably the solution. I don't think it's the addition of an IP Address that's dropping the tunnel but rather the change of default gateway. I could be wrong, but I suspect the gateway change messes it all up. So, select the option in the SoftEther client's connection properties to not update routing table. It's in the Advanced area.
Gerard1
Post by Gerard1 » Tue Sep 08, 2020 5:25 am
This really helped. thanks.
