[SOLVED] VPNServer on 4G - vpncmd instructions needed
Freds
Post by Freds » Mon Sep 21, 2020 3:19 pm
Hello all,
I am looking for a way to connect to a SE server behind a 4G connection with an OpenVPN client, and I found SoftEther which could probably solve my problem if only I could set it up properly. I am working in a linux-only environment, and I have no GUI server manager that I can click on all available options. vpncmd is my friend, but I need help as to which options to activate to make this work.
So far, when I create the OpenVPN config zip, I can see that it points to a domain which in turn points to the CGNated IP, but it doesn't seem to traverse it. I also noted that the certificate I generated is not included in the ovpn file.
Any pointers to the right direction would be welcome.
Thanks,
F.
sky59
Re: VPNServer on 4G - vpncmd instructions needed
Post by sky59 » Mon Sep 21, 2020 5:25 pm
Use windows machine with manager.
No headache
Freds
Re: [SOLVED] VPNServer on 4G - vpncmd instructions needed
Post by Freds » Tue Sep 22, 2020 10:25 am
I managed to make this work:
  1. activate VPN Azure
  2. connect using the SoftEther VPN Client
  3. user connects through the vpnazure.net link, not the softether.net one
In vpncmd:
VpnAzureSetEnable yes
VpnAzureGetStatus
sky59
Post by sky59 » Tue Sep 22, 2020 12:31 pm
It is tooooo slow over azure
Freds
Post by Freds » Tue Sep 22, 2020 4:14 pm
Right. But it is the only one that can traverse carrier-grade NAT, at least with on the network I'm using. Unless you know of a way to do it with softether.net -- each time I try, it fails to connect.
sky59
Post by sky59 » Fri Sep 25, 2020 12:02 pm
If it works over azure it can work also without it.
You need public ip address on server side and correct setting like port forwarding and so on...
Because azurre is nothing else but server, in this case you do not need public ip because it is at azure
But it is slow because Tsukuma university can not serve so many connections at high speed
