HashedPassword hash function is base64(sha0(password))
yahuu
Post by yahuu » Sun Oct 11, 2020 3:07 pm
I needed to update the server administrator password by editing the "HashedPassword" value in vpn_server.config file.
I finally have found the hash function softether uses which is base64(sha0(password))
Just wanted to share this to save other people's time.
Thank you
PS: if anyone needs java implementation please reply to this thread
jpl
Re: HashedPassword hash function is base64(sha0(password))
Post by jpl » Wed Jan 27, 2021 7:44 am
can you upload the code to github?
thanks
kotten
Post by kotten » Thu Feb 04, 2021 12:19 pm
Thank you
Shoot. I have tried to understand how I would be able to create that using a very simple bashscript (such as
 echo "passwd" | shasum | base64
) or such but I can't seem to grasp it. Shoot and post your java implementation to get from "cleartext" to hashed. They seem to always be 29 characters.
