vpnazure.net access
johncarl.santos
vpnazure.net access
Post by johncarl.santos » Sun Oct 25, 2020 3:54 pm
Anybody using vpnazure.net?
My setup is using vpnazure.net and it is working fine just hours ago. Then just now, I cannot access both of my VPN servers in different sites, both using vpnazure.net.
Is the vpnazure.net service down?
Thank you
djg1873
Re: vpnazure.net access
Post by djg1873 » Sun Oct 25, 2020 4:17 pm
I have the same issue. Three separate vpnazure vpns all not working.
Regards, Dean.
johncarl.santos
Post by johncarl.santos » Sun Oct 25, 2020 4:21 pm
Hi djg1873, did this happen just right now / few hours ago?
djg1873
Post by djg1873 » Sun Oct 25, 2020 5:25 pm
Yes.
djg1873
Post by djg1873 » Sun Oct 25, 2020 5:26 pm
Same time you reported it.
allaboutthebase
Post by allaboutthebase » Sun Oct 25, 2020 5:45 pm
Same here.
On 2 locations Im getting retries constantly.
Is there something down ?
What services are needed externally from me for Softether to work ?
BTW. Im not using azure and I tried IP address in case there was an issue with the dynamic IP address.
djg1873
Post by djg1873 » Sun Oct 25, 2020 7:57 pm
One of my vpnazure VPNs has just started working again.
djg1873
Post by djg1873 » Sun Oct 25, 2020 8:19 pm
Second one back now.
djg1873
Post by djg1873 » Sun Oct 25, 2020 8:56 pm
All back now.
johncarl.santos
Post by johncarl.santos » Mon Oct 26, 2020 2:52 am
Thanks djg1873, my services all up now also.
johncarl.santos
Post by johncarl.santos » Mon Oct 26, 2020 2:55 am
allaboutthebase wrote: ↑
Same here.
my isp only comes with dynamic IP thats why we are using vpnazure.net
allaboutthebase
Post by allaboutthebase » Mon Oct 26, 2020 9:47 am
Is it down again?
dmei
Post by dmei » Sun Nov 01, 2020 12:45 am
I still do not have access via azure. I use VPN Client Pro on Android, and it has logging of what goes wrong.
2020-11-01 10:30:39 Connecting request by user
2020-11-01 10:30:39 Loaded OpenSSL 1.0.2l  25 May 2017
2020-11-01 10:30:40 try to connect to X.X.X.X:443
2020-11-01 10:30:40 Connecting to X.X.X.X:443 {this is mhost.vpnazure.net}
2020-11-01 10:30:41 Ca is not set, certificate verify error ignored:
2020-11-01 10:30:41   certificate: /C=SE/O=AddTrust AB/OU=AddTrust External TTP Network/CN=AddTrust External CA Root
2020-11-01 10:30:41   depth: 3 error: self signed certificate in certificate chain(19)
2020-11-01 10:30:41 Certificate verify error:
2020-11-01 10:30:41   depth: 3 error: certificate has expired(10)
2020-11-01 10:30:41 SSL connect error "error:14090086:SSL routines:ssl3_get_server_certificate:certificate verify failed"
2020-11-01 10:30:41 release all buf from link read queue(0)
2020-11-01 10:30:41 release all buf from link write queue(0)
2020-11-01 10:30:41 release all buf from tun read queue(0)
2020-11-01 10:30:41 release all buf from tun write queue(0)
2020-11-01 10:30:41 PacketBuffer::freeAll() free all buffer pool(0)
2020-11-01 10:30:41 Wait 5 seconds...
2020-11-01 10:30:43 Disconnecting request by user
If I do an SSL check using sslshopper.com I get these warnings:
  • One of the root or intermediate certificates has expired (155 days ago).
  • One of the certificates is signed with a SHA1 signature. We recommend that you reissue or replace this certificate with one that uses a SHA-2 signature. Contact your SSL provider about how to do this. Read more about the SHA-1 deprecation here.
The attached graphic shows the chain, and it looks like Comodo RSA had a certificate expire back in March.
Common name: COMODO RSA Certification Authority
Organization: COMODO CA Limited
Valid from May 30, 2000 to May 30, 2020
Serial Number: 2766ee56eb49f38eabd770a2fc84de22
Signature Algorithm: sha384WithRSAEncryption
Issuer: AddTrust External CA Root
I ran an SSLLabs test on the host too, and the results are also attached. Lots of problems from the look of it.
Perhaps the admins of the cloud instance can tighten up the SSL settings and update the certificates. It is a great service (when it works) and is the only way I can make a VPN connection to systems that connect to the internet via CGNAT.
johncarl.santos
Post by johncarl.santos » Wed Feb 17, 2021 1:12 pm
Is vpnazure.net access down again?
