Good afternoon everyone, I am quite new to this although I have installed some vpn with this software with a fantastic use.
Today I installed the software on a new Dell server and I am encountering the following problem:
Sometimes the Localbridge sends the DHCP ip address and sometimes not, I attach a log. As you will see, in some connection it connects the user but does not give him IP
I can't understand what happens?
Please can you help me?
Thanks in advance
Joan
2020-11-09 20:49:31.757 ------------------------------------------------------
2020-11-09 20:49:31.757 SoftEther VPN Server Version 4.34 Build 9744 (English)
2020-11-09 20:49:31.757 Compiled 2020/03/20 19:23:20 by buildsan at crosswin
2020-11-09 20:49:31.757 Log Messages are written with UTF-8 Encoding Format.
2020-11-09 20:49:31.757 The SoftEther VPN Server has been started.
2020-11-09 20:49:31.757 IPsec Module: The IPsec ver 2.0 (ISAKMP/IKEv1) processing module is started.
2020-11-09 20:49:31.757 OpenVPN Module: The OpenVPN Server Module is starting.
2020-11-09 20:49:31.757 Loading the configuration file.
2020-11-09 20:49:31.773 Monitoring the directory "C:\Program Files\SoftEther VPN Server". If the amount of available free disk space becomes less than 8,00 GBytes, the backup files for log files and configurations that are saved on the sub-directories of this directory will be automatically deleted in the order of oldest first. The amount of free disk space that determines when to start deletion can be modified by changing the "AutoDeleteCheckDiskFreeSpaceMin" item in the configuration file.
2020-11-09 20:49:31.789 Virtual Hub "VPN" has been started.
2020-11-09 20:49:31.789 The MAC address of Virtual Hub "VPN" is "00-AE-90-33-2E-46".
2020-11-09 20:49:31.789 [HUB "VPN"] The Virtual Hub is now online.
2020-11-09 20:49:31.789 TCP Listener (port 443) is starting.
2020-11-09 20:49:31.789 TCP Listener (port 443) has started. Now listening for connection from client.
2020-11-09 20:49:31.789 TCP Listener (port 992) is starting.
2020-11-09 20:49:31.789 TCP Listener (port 1194) is starting.
2020-11-09 20:49:31.789 TCP Listener (port 992) has started. Now listening for connection from client.
2020-11-09 20:49:31.789 TCP Listener (port 1194) has started. Now listening for connection from client.
2020-11-09 20:49:31.789 TCP Listener (port 5555) is starting.
2020-11-09 20:49:31.789 TCP Listener (port 5555) has started. Now listening for connection from client.
2020-11-09 20:49:31.789 [HUB "VPN"] The Local Bridge connection "Broadcom 573xx Ethernet Adapter (2) (ID=0352157685)" has started. The bridge session "SID-LOCALBRIDGE-1" was created.
2020-11-09 20:49:31.789 The configuration file has been loaded.
2020-11-09 20:49:31.789 Starting the automatically saving background task. The interval between auto-saves is 300 seconds. You can change the interval by changing the parameter AutoSaveConfigSpan in the configuration file.
2020-11-09 20:49:32.054 [HUB "VPN"] Session "SID-LOCALBRIDGE-1": A Local Bridge connection to physical Ethernet interface "Broadcom 573xx Ethernet Adapter (2) (ID=0352157685)" was started.
2020-11-09 20:49:46.005 On the TCP Listener (Port 443), a Client (IP address 83.45.164.101, Host name "101.red-83-45-164.dynamicip.rima-tde.net", Port number 60820) has connected.
2020-11-09 20:49:46.005 For the client (IP address: 83.45.164.101, host name: "101.red-83-45-164.dynamicip.rima-tde.net", port number: 60820), connection "CID-1-D0D0B23BA7" has been created.
2020-11-09 20:49:46.098 SSL communication for connection "CID-1-D0D0B23BA7" has been started. The encryption algorithm name is "TLS_AES_256_GCM_SHA384".
2020-11-09 20:49:46.395 Connection "CID-1-D0D0B23BA7": 1 Virtual Hub servers have been enumerated on this server.
2020-11-09 20:49:46.426 Connection "CID-1-D0D0B23BA7" terminated by the cause "No error." (code 0).
2020-11-09 20:49:46.426 Connection "CID-1-D0D0B23BA7" has been terminated.
2020-11-09 20:49:46.426 The connection with the client (IP address 83.45.164.101, Port number 60820) has been disconnected.
2020-11-09 20:49:48.067 On the TCP Listener (Port 443), a Client (IP address 83.45.164.101, Host name "101.red-83-45-164.dynamicip.rima-tde.net", Port number 60823) has connected.
2020-11-09 20:49:48.067 For the client (IP address: 83.45.164.101, host name: "101.red-83-45-164.dynamicip.rima-tde.net", port number: 60823), connection "CID-2-DD36F0FAE2" has been created.
2020-11-09 20:49:48.129 SSL communication for connection "CID-2-DD36F0FAE2" has been started. The encryption algorithm name is "TLS_AES_256_GCM_SHA384".
2020-11-09 20:49:48.254 [HUB "VPN"] The connection "CID-2-DD36F0FAE2" (IP address: 83.45.164.101, Host name: 101.red-83-45-164.dynamicip.rima-tde.net, Port number: 60823, Client name: "SoftEther VPN Client", Version: 4.34, Build: 9745) is attempting to connect to the Virtual Hub. The auth type provided is "Password authentication" and the user name is "pga".
2020-11-09 20:49:48.254 [HUB "VPN"] Connection "CID-2-DD36F0FAE2": Successfully authenticated as user "pga".
2020-11-09 20:49:48.254 [HUB "VPN"] Connection "CID-2-DD36F0FAE2": The new session "SID-PGA-2" has been created. (IP address: 83.45.164.101, Port number: 60823, Physical underlying protocol: "Standard TCP/IP (IPv4)")
2020-11-09 20:49:48.254 [HUB "VPN"] Session "SID-PGA-2": The parameter has been set. Max number of TCP connections: 2, Use of encryption: Yes, Use of compression: No, Use of Half duplex communication: No, Timeout: 20 seconds.
2020-11-09 20:49:48.254 [HUB "VPN"] Session "SID-PGA-2": VPN Client details: (Client product name: "SoftEther VPN Client", Client version: 434, Client build number: 9745, Server product name: "SoftEther VPN Server (64 bit)", Server version: 434, Server build number: 9744, Client OS name: "Windows 10", Client OS version: "Build 19041, Multiprocessor Free (19041.vb_release.191206-1406)", Client product ID: "--", Client host name: "DESKTOP-4EP1J4A", Client IP address: "192.168.1.42", Client port number: 60823, Server host name: "81.42.222.251", Server IP address: "81.42.222.251", Server port number: 443, Proxy host name: "", Proxy IP address: "0.0.0.0", Proxy port number: 0, Virtual Hub name: "VPN", Client unique ID: "A7D84887850AA31155868722E413AE32")
2020-11-09 20:49:48.489 [HUB "VPN"] Session "SID-LOCALBRIDGE-1": The DHCP server of host "00-A0-26-D3-74-1E" (192.168.10.1) on this session allocated, for host "SID-PGA-2" on another session "5E-B6-7A-F8-29-6E", the new IP address 192.168.10.112.[/b]
2020-11-09 20:49:49.457 On the TCP Listener (Port 443), a Client (IP address 83.45.164.101, Host name "101.red-83-45-164.dynamicip.rima-tde.net", Port number 60825) has connected.
2020-11-09 20:49:49.457 For the client (IP address: 83.45.164.101, host name: "101.red-83-45-164.dynamicip.rima-tde.net", port number: 60825), connection "CID-3-E9517FA235" has been created.
2020-11-09 20:49:49.535 SSL communication for connection "CID-3-E9517FA235" has been started. The encryption algorithm name is "TLS_AES_256_GCM_SHA384".
2020-11-09 20:49:49.566 Connection "CID-3-E9517FA235" has been terminated.
2020-11-09 20:49:55.753 On the TCP Listener (Port 443), a Client (IP address 83.45.164.101, Host name "101.red-83-45-164.dynamicip.rima-tde.net", Port number 55376) has connected.
2020-11-09 20:49:55.753 For the client (IP address: 83.45.164.101, host name: "101.red-83-45-164.dynamicip.rima-tde.net", port number: 55376), connection "CID-4-DED5BD36BA" has been created.
2020-11-09 20:49:55.846 SSL communication for connection "CID-4-DED5BD36BA" has been started. The encryption algorithm name is "TLS_AES_256_GCM_SHA384".
2020-11-09 20:49:56.050 Connection "CID-4-DED5BD36BA": 1 Virtual Hub servers have been enumerated on this server.
2020-11-09 20:49:56.096 Connection "CID-4-DED5BD36BA" terminated by the cause "No error." (code 0).
2020-11-09 20:49:56.096 Connection "CID-4-DED5BD36BA" has been terminated.
2020-11-09 20:49:56.096 The connection with the client (IP address 83.45.164.101, Port number 55376) has been disconnected.
2020-11-09 20:50:07.922 On the TCP Listener (Port 443), a Client (IP address 83.45.164.101, Host name "101.red-83-45-164.dynamicip.rima-tde.net", Port number 55378) has connected.
2020-11-09 20:50:07.922 For the client (IP address: 83.45.164.101, host name: "101.red-83-45-164.dynamicip.rima-tde.net", port number: 55378), connection "CID-5-C7A558914F" has been created.
2020-11-09 20:50:08.000 SSL communication for connection "CID-5-C7A558914F" has been started. The encryption algorithm name is "TLS_AES_256_GCM_SHA384".
2020-11-09 20:50:08.141 [HUB "VPN"] The connection "CID-5-C7A558914F" (IP address: 83.45.164.101, Host name: 101.red-83-45-164.dynamicip.rima-tde.net, Port number: 55378, Client name: "SoftEther VPN Client", Version: 4.34, Build: 9745) is attempting to connect to the Virtual Hub. The auth type provided is "Password authentication" and the user name is "pga".
2020-11-09 20:50:08.141 [HUB "VPN"] Connection "CID-5-C7A558914F": Successfully authenticated as user "pga".
2020-11-09 20:50:08.141 [HUB "VPN"] Connection "CID-5-C7A558914F": The new session "SID-PGA-3" has been created. (IP address: 83.45.164.101, Port number: 55378, Physical underlying protocol: "Standard TCP/IP (IPv4)")
2020-11-09 20:50:08.141 [HUB "VPN"] Session "SID-PGA-3": The parameter has been set. Max number of TCP connections: 2, Use of encryption: Yes, Use of compression: No, Use of Half duplex communication: No, Timeout: 20 seconds.
2020-11-09 20:50:08.141 [HUB "VPN"] Session "SID-PGA-3": VPN Client details: (Client product name: "SoftEther VPN Client", Client version: 434, Client build number: 9745, Server product name: "SoftEther VPN Server (64 bit)", Server version: 434, Server build number: 9744, Client OS name: "Windows Server 2016", Client OS version: "Build 17763, Multiprocessor Free (17763.rs5_release.180914-1434)", Client product ID: "--", Client host name: "Server2019.pgrup.local", Client IP address: "192.168.1.137", Client port number: 55378, Server host name: "81.42.222.251", Server IP address: "81.42.222.251", Server port number: 443, Proxy host name: "", Proxy IP address: "0.0.0.0", Proxy port number: 0, Virtual Hub name: "VPN", Client unique ID: "792217E914A1EBBFA1FFD4DD6F65AA79")
2020-11-09 20:50:09.766 On the TCP Listener (Port 443), a Client (IP address 83.45.164.101, Host name "101.red-83-45-164.dynamicip.rima-tde.net", Port number 55383) has connected.
2020-11-09 20:50:09.766 For the client (IP address: 83.45.164.101, host name: "101.red-83-45-164.dynamicip.rima-tde.net", port number: 55383), connection "CID-6-E4DB12A60A" has been created.
2020-11-09 20:50:09.844 SSL communication for connection "CID-6-E4DB12A60A" has been started. The encryption algorithm name is "TLS_AES_256_GCM_SHA384".
2020-11-09 20:50:09.875 Connection "CID-6-E4DB12A60A" has been terminated.
2020-11-09 20:50:37.416 [HUB "VPN"] Session "SID-LOCALBRIDGE-1": The DHCP server of host "00-A0-26-D3-74-1E" (192.168.10.1) on this session allocated, for host "SID-PGA-3" on another session "5E-47-C4-BF-C7-A1", the new IP address 192.168.10.121.
Bridge problems
jnbruguer
Re: Bridge problems
Hi people,
I'm working hard to try understand what happens with local bridge.
It works fine with 2 sessions but the local bridge don't give an IP to the 3rd session an more.
I read the documentation and I think that the problem is the ethernet controler, this is:
Broadcom NetXtreme E-Series Advanced Dual-port 10GBASE-T Ethernet LOM
It's a new Dell server, and I read in documentation that recomended adapters are:
Intel Intel PRO or Gigabit Adapter series
100Base-TX
1000Base-T
1000Base-SX
1000Base-LX
10GBase-SR
10GBase-LR
Broadcom Broadcom NetXtreme series
100Base-TX
1000Base-T
3Com 3Com series
100Base-TX
1000Base-T
Do you thing that the Broadcom new adapter it's the problem?
Thanks
Joan
100Base-TX
1000Base-T
1000Base-SX
1000Base-LX
10GBase-SR
10GBase-LR
100Base-TX
1000Base-T
3Com 3Com series
100Base-TX
1000Base-T
Thanks
Joan
Afakename
Re: Bridge problems
Hi Jnbruguer,
Are you running Windows on the Dell as a physical server? Or the Dell is virtualized, and the SEVPN is running as a VM?
If you are running the Dell as a physical host, check the switch to ensure you are not implicitly disabling promiscuous mode and mac spoofing (port security). Both options are required for bridging to operate.
