I had a working SoftEther VPN running on a Windows Server, connecting to both DDNS hostname and VPN Azure hostname working.
A few days ago I created another server with a different hostname, but now clients can only use the VPN Azure hostname to connect, using the DDNS name gives Error Code 1. Within the network I can still connect to the DDNS name.
I suspect that both server are on the same public IP might have caused some problem, but even shutting one of the SoftEther hubs down won't help.
Connection to DDNS hostname no longer working
SEuser19
