how to enable vpn on windows 7 ssl?
dminster
I googled the windows 7 ssl configuration but I can't figure out where he got the ip and why it's different and there's no server configuration What do he write in the host name, is it his vps?
Afakename
Re: how to enable vpn on windows 7 ssl?
Hi dminster,
1. On the machine running the Softether VPN, open chrome, enter https://whatismyip.com
2. Note the IP in step 1
3. On the Windows 7 client PC, under Host Name, enter the IP address from 1) above
4. Save the config
5. Good luck from mother Russia
4. Save the config
dminster
if I'm talking about my ip, then what's the point of it?
