server configuration file
gifegayu
Post by gifegayu » Thu Dec 10, 2020 9:10 am
I'm testing Softether VPN on my linux test machine (CentOS 7).
It apperas that when launching vpnserver for the first time, a default configuration files and a backup directory are being created with default values. One of the values is Listener on port 443 being enabled. I would like this listener to be disabled by default for it interferes with another daemon listening on this port.
How can I generate a custom configuration file before I start the vpnserver or adjust the default settings _before_ starting the vpn server please?
Thank you.
