Simulating LAN 2 LAN with virtualbox not able to connect
avezan
Post by avezan » Thu Dec 10, 2020 9:29 pm
Greetings,
I have been trying to get this working for last 5 days still no success. I'll try to elaborate in as much detail as possible.
Basic Architecture:
- HeadQuarter (TOKYO) = no lan only server with single hub named "mainhub" on Windows 10.
[Simulated by SoftEther server running on Windows 10]
- Branch (OSAKA) = A router having a SoftEther bridge on openwrt and a single system with TinyCore OS connected in lan.
[Simulated by Virtualbox on Windows having two running VM's, one of openwrt, another TinyCore]
- Branch (TSUKUBA) = A router having a SoftEther bridge on openwrt and a single system with TinyCore OS connected in lan.
[Simulated by Virtualbox on Kubuntu having two running VM's, one of openwrt, another TinyCore]
Systems(2 Pc's One Win10, another Kubuntu 20.04):
1. Windows OS 10
- SofthEther
  • s-1. Has got SoftEther VPN Server (Main) with a HUB named "mainhub"
- Interfaces
  • i-1. Realtec Wireless Adapter with IP statically set as 192.168.1.5
2. Virtualbox on Windows 10 having following VMs
a) VM with Openwrt x86 OS
- SoftEther
  • s-1. Has got SoftEther VPN Bridge(edge) with HUB named "BRIDGE" cascading to "mainhub"
  • s-2. This VPN Bridge(edge) has a Local Bridge named "br2servWin" with interface "br-lan" i.e b2servWin = "BRIDGE" <--> "br-lan"
- Interfaces
  • i-1. eth0 which is bridged network with Windows "Wireless Adapter". IP statically set as 192.168.1.8
  • i-2. eth1 which is virtualbox adapter named "Virtual Box Adapter" having ip 192.168.56.1/24
  • i-3. eth2 which is "internal network" named "intnet" and in OPENWRT it is mapped by interface named "br-lan". IP for OpenWRT DHCP has been fixed at 10.1.15.1/24
b) VM with TinyCore OS
- Nothing from softether
- Interfaces
  • i-1. eth0 which is internal network "intnet" which get IP from br-lan's DHCP sometimes 10.1.15.180
3. Virtualbox on Kubuntu 20.04 having following VMs
- SoftEther
  • s-2. This VPN Bridge(edge) has a Local Bridge named "br2serv" with interface "br-lan" i.e b2serv = "BRIDGE" <--> "br-lan"
- Interfaces
  • i-1. eth0 which is bridged network with Kubuntu's "Wireless Adapter(wlan0)". IP statically set as 192.168.1.7
  • i-2. eth1 which is virtualbox adapter named "vboxnet0" having ip 192.168.56.1/24
  • i-3. eth2 which is "internal network" named "intnet" and in OPENWRT it is again mapped by interface named "br-lan". IP for OpenWRT DHCP has been fixed at 10.1.16.1/24
- Interfaces
  • i-1. eth0 which is internal network "intnet" which gets IP from br-lan's DHCP sometimes 10.1.16.180
4. A wireless router with address 192.168.1.1/24 and simulates internet by connecting directly to
  • - 192.168.1.5(Win10)
  • - 192.168.1.7(Kubuntu/VM/OpenWrt)
  • - 192.168.1.8(Win10/VM/OpenWrt)
Working:
1. All Edges i.e. 192.168.1.8(Win10/VM/OpenWrt) and 192.168.1.7(Kubuntu/VM/OpenWrt) are cascading to main server 192.168.2.5(Win10).
2. Each edge has its local bridge as operational.
3. I can ping among 192.168.1.5(Win10), 192.168.1.7(Kubuntu/VM/OpenWrt), 192.168.1.8(Win10/VM/OpenWrt)
Not Working:
1. However I can't ping 10.1.16.180(Kubuntu/VM/TinyCore) from 10.1.15.180(Win10/VM/TinyCore) or vice versa.
Further in real requirements both VM's Openwrt LAN (i.e OSAKA and TSUKUBA) may have same IP range say 10.1.0.0/24.
Can anyone help me figuring what am I missing or I am not understanding the VPN at all. :(
Afakename
Re: Simulating LAN 2 LAN with virtualbox not able to connect
Post by Afakename » Fri Dec 11, 2020 7:07 am
Bridging requires the bridge interface to be set/enable 1) promiscuous mode 2) MAC spoofing. In VM environments, these 2 options usually come disabled. Can you kindly confirm these 2 options are enabled? The bridge status within SEVPN may be misleading and display as operational, but until the bridging requirements are met, the bridge is not going to work.
avezan
Post by avezan » Fri Dec 11, 2020 12:02 pm
Thanks for the reply.
I somehow succeded making it work yesterday. Promiscous mode was enabled so was mac spoofing(not very sure but sessions had different mac).
However adding two more hubs on server, and a tap device on each router, followed by setting L3 routing in server, I was able to ping across both tinycores. But now have got other problems like
  • Ping packet drop rate is high.
  • Can't make it work without enabling SecureNAT on both server hubs
For the first one I'll try rawpacket disabling. But for the second one I have no idea how to communicate with the corresponding server hub without securenat as hub wont have any ip address where tap can forward its packet.
