Compile sources for Windows
sky59
Post by sky59 » Tue Dec 15, 2020 11:41 am
I need to compile SE for Windows.
I installed VS2008+SP1 on Windows XP 32 bit. Then I start BuildAll.cmd
Attched is log what is going on in terminal window.
Please, search for text "error(s)" It can not find some files. I already disabled firewall. There are a lot of reasons for this problem.
If anybody ever compiled (or even not but knows) please help. Would be appreciated
Thanx in advance
NOTE: attached log needs to have extension renamed to zip and then unzipped in a standard way
log_zip.txt
sky59
Re: Compile sources for Windows
Post by sky59 » Sat Dec 19, 2020 7:43 am
On virtual machine W8 64bit it compiles ok.
So wxp 32bit is not ok for this
