Suggestion: Easier hassle free method of enable a split tunnel?
I'm currently using the mainstream vpn service expressvpn at the moment because they advertise that they have a split tunneling feature. I gave it a try and it was just very easy to use. Go into the options, enable split tunnel, choose the specific program that I want to use the VPN for and it's done just like that. I really wished softether had the same thing, something that is just so easy to use. Hopefully the developers will implement a painless method of enable split tunneling in the future.
Re: Suggestion: Easier hassle free method of enable a split tunnel?
I think it has nothing to do with vpn.
It must be operating system deciding which route to use for particular aplication
Does expressvpn support also linux?
