Some background :
Server on raspberry pi 4
OS - Raspbian
I don't have public IP, contacted ISP
can I use NAT-t or Azure on iOS, to bypass NAT?
Connect from iOS to raspberry server under NAT
Re: Connect from iOS to raspberry server under NAT
Enable azure on rpi
From ios connect to vpnxxxx.azure.net
Keep in mind it is about 1Mb/s up/down
yes, just trying to do the same.
can you show some more steps/details on how to setup?
