spice tls disconnected
the_cr
Post by the_cr » Wed Jan 13, 2021 4:09 pm
Good day .
i have problem with softether server last rtm version.
after connected from any os with softether client or openvpnclient
with or without encryption ,
i established tls connection on external server with kvm/spice protocol (remote desktop)
this connection disconnected after one minute (max 5) with error tls connection disconnected with remote server.
i can restart this connection - not problem - but this not really to work.
i can`t find docs for config file .
Help, if you can !
tnx
the_cr
Re: spice tls disconnected
Post by the_cr » Fri Jan 29, 2021 12:33 pm
problem solved after reconfigure server and change from softether virtual NAT to standart NAT with iptables configuration.
