I have installed Softether VPN Server on Centos.
Than configured the server:
-make a new virtual hub
-make a new user
-Enable secureNAT
-etc
The last I generate configuration file for openVPN
But when I connect client with openVPN to the server, it doesnt work..
Anybody help me. Thanks
How to connnect OpenVPN Client to Softether Server?
Budi
Budi
Re: How to connnect OpenVPN Client to Softether Server?
This is the error on OpenVPN client.
Anyone help me?
Anyone help me?
Softdog
I have never used that client but it looks like you are trying to connect using a certificate as authentication, without having issued one.
Have you tried to change to password authentication instead? If that works, read up on using certificates and try using that method again.
Budi
Thanks Dear Softdog for your suggestion. I will try and try and try to solve it.
But, if anyone have tried it and solved "using openvpn client to access softether vpn server". Please help me the step by step to solve it. Thanks very much..
If you change server cert, you have to remake the OpenVPN configfile.
