Cannot reach shared network drive from abroad
cstamas92
Post by cstamas92 » Thu Jan 21, 2021 1:02 pm
Hello!
I need your help in the following situation:
Our company uses Softether VPN for years without any serious problem. Some of our colleagues are in Serbia now, and they cannot reach our shared network drive in Hungary (via VPN).
The VPN connects successfully but in the windows explorer they can not reach the target shared folder. They tried remapping it but after they de-attach it they can not map it anymore.
I'm looking forward to any ideas.
Tamas
sky59
Re: Cannot reach shared network drive from abroad
Post by sky59 » Thu Jan 21, 2021 3:23 pm
So you can reach it from non-abroad? Over the internet and VPN?
cstamas92
Post by cstamas92 » Fri Jan 22, 2021 7:10 am
Yes I can.
sky59
Post by sky59 » Fri Jan 22, 2021 7:21 am
The only possibility is you are in China behind GF
ethanolson
Post by ethanolson » Thu Jan 28, 2021 12:12 am
It could be a DNS configuration issue. Can they reach the network resource by IP address? If so, then it's a DNS issue. If they cannot reach the resource by IP address, but their own VPN IP address is good, then it may be a client routing table issue.
Pierneefie
Post by Pierneefie » Thu Jan 28, 2021 11:45 am
I have the same problem
When using smartphone data on the move VPN works but can not see shared or connect to items on server ?
