is there any chance to active PAP Radius requests on the latest unstable version "Version: 5.01, Build: 9674"? In the Build-Version 9674 this is the Radius request:
Ready to process requests
(1) Received Access-Request Id 1 from 127.0.0.1:56271 to 127.0.0.1:1812 length 305
(1) User-Name = "tgm"
(1) Acct-Session-Id = "\000\001"
(1) NAS-IP-Address = 0.0.0.0
(1) Service-Type = Framed-User
(1) MS-RAS-Vendor = 311
(1) MS-RAS-Version = "MSRASV5.20"
(1) NAS-Port-Type = Virtual
(1) Tunnel-Type:0 = PPTP
(1) Tunnel-Medium-Type:0 = IPv4
(1) Called-Station-Id = "Admin-VPN"
(1) Calling-Station-Id = "1.2.3.4"
(1) Tunnel-Client-Endpoint:0 = "1.2.3.4"
(1) MS-RAS-Client-Version = "MSRASV5.20"
(1) MS-RAS-Client-Name = "1.2.3.4"
(1) MS-CHAP-Challenge = 0x2cae658ba695695263fe872be831484d
(1) MS-CHAP2-Response = 0x00000e1a3c3ec4ce468d1541af6432c98f2b0000000000000000acc0af882729385edeb53b5b4d23706a6dbdfdc03bfd5005
(1) NAS-Identifier = "SoftEther VPN Server Developer Edition"
(1) Proxy-State = 0x4c333a4c325450
(1) # Executing section authorize from file /etc/freeradius/3.0/sites-enabled/default
(1) authorize {
(1) auth_log: EXPAND /var/log/freeradius/radacct/%{%{Packet-Src-IP-Address}:-%{Packet-Src-IPv6-Address}}/auth-detail-%Y%m%d
(1) auth_log: --> /var/log/freeradius/radacct/127.0.0.1/auth-detail-20210201
(1) auth_log: /var/log/freeradius/radacct/%{%{Packet-Src-IP-Address}:-%{Packet-Src-IPv6-Address}}/auth-detail-%Y%m%d expands to /var/log/freeradius/radacct/127.0.0.1/auth-detail-20210201
(1) auth_log: EXPAND %t
(1) auth_log: --> Mon Feb 1 12:45:49 2021
(1) [auth_log] = ok
And in latest stable version this is the radius request:
(0) Received Access-Request Id 2 from 127.0.0.1:42332 to 127.0.0.1:1812 length 144
(0) User-Name = "tgm"
(0) User-Password = "409679"
(0) NAS-Identifier = "SoftEther VPN Server"
(0) Service-Type = Framed-User
(0) NAS-Port-Type = Virtual
(0) Tunnel-Type:0 = PPTP
(0) Tunnel-Medium-Type:0 = IPv4
(0) Called-Station-Id = "Admin-VPN"
(0) Calling-Station-Id = "1.2.3.4"
(0) Tunnel-Client-Endpoint:0 = "1.2.3.4"
(0) Proxy-State = 0x4c333a4c325450
(0) # Executing section authorize from file /etc/freeradius/3.0/sites-enabled/default
(0) authorize {
(0) auth_log: EXPAND /var/log/freeradius/radacct/%{%{Packet-Src-IP-Address}:-%{Packet-Src-IPv6-Address}}/auth-detail-%Y%m%d
(0) auth_log: --> /var/log/freeradius/radacct/127.0.0.1/auth-detail-20210201
(0) auth_log: /var/log/freeradius/radacct/%{%{Packet-Src-IP-Address}:-%{Packet-Src-IPv6-Address}}/auth-detail-%Y%m%d expands to /var/log/freeradius/radacct/127.0.0.1/auth-detail-20210201
(0) auth_log: EXPAND %t
(0) auth_log: --> Mon Feb 1 12:44:24 2021
(0) [auth_log] = ok
My Problem is, that I need for further actions the "User-Password" statement in the request, which I can only have with PAP requests.
Best, Tobias
