The Server Manager not work on OsX BigSur:
The error are : Winetricks[16153:727046] *** WARNING: Textured window <NSWindow: 0x100320010> is getting an implicitly transparent titlebar. This will break when linking against newer SDKs. Use NSWindow's -titlebarAppearsTransparent=YES instead.
/Applications/VPN Server Manager.app/Contents/MacOS/startwine: line 60: /Applications/VPN Server Manager.app/Contents/MacOS/../Resources/Wine.bundle/Contents/Resources/bin/wine: Bad CPU type in executable
Thanks
Server Manager for OSX not work on BigSur
Re: Server Manager for OSX not work on BigSur
Server Manager is actually a windows binary that is packaged with 32bit Wine (windows emulator). However 32bit Wine currently does not run on OS X Catalina or BIg Sur, which only has 64bit support.
