i have a problem with "openvpn connect" version 3 client under windows 10.
I have set up softether without any problems and with its client it works properly, but if I use the client "openvpn v3" [ https://openvpn.net/downloads/openvpn-c ... ndows.msi ] the routing doesn't work; if i use other version of openvpn client or softether vpn client works correctly
with version 3.X i get this routing table
C:\Users\mmoscheni>route print -4
Elenco interfacce
14...5e ba 55 a9 52 cf ......VPN Client Adapter - VPN
11...00 ff 57 f3 97 6d ......TAP-Windows Adapter V9 for OpenVPN Connect
6...........................Wintun Userspace Tunnel
10...00 0c 29 1d e3 b9 ......Intel(R) 82574L Gigabit Network Connection
15...00 ff 78 66 96 8e ......TAP-Windows Adapter V9
IPv4 Tabella route
Route attive:
Indirizzo rete Mask Gateway Interfaccia Metrica
0.0.0.0 0.0.0.0 192.168.100.1 192.168.100.83 25
10.0.0.0 255.0.0.0 192.168.30.14 192.168.30.13 257
91.196.XX.XX 255.255.255.255 192.168.100.1 192.168.100.83 281
127.0.0.0 255.0.0.0 On-link 127.0.0.1 331
127.0.0.1 255.255.255.255 On-link 127.0.0.1 331
127.255.255.255 255.255.255.255 On-link 127.0.0.1 331
192.168.30.0 255.255.255.0 192.168.30.14 192.168.30.13 257
192.168.30.12 255.255.255.252 On-link 192.168.30.13 257
192.168.30.13 255.255.255.255 On-link 192.168.30.13 257
192.168.30.15 255.255.255.255 On-link 192.168.30.13 257
192.168.100.0 255.255.255.0 On-link 192.168.100.83 281
192.168.100.83 255.255.255.255 On-link 192.168.100.83 281
192.168.100.255 255.255.255.255 On-link 192.168.100.83 281
224.0.0.0 240.0.0.0 On-link 127.0.0.1 331
224.0.0.0 240.0.0.0 On-link 192.168.30.13 257
224.0.0.0 240.0.0.0 On-link 192.168.100.83 281
255.255.255.255 255.255.255.255 On-link 127.0.0.1 331
255.255.255.255 255.255.255.255 On-link 192.168.30.13 257
255.255.255.255 255.255.255.255 On-link 192.168.100.83 281
Route permanenti:
Nessuna
C:\Users\mmoscheni>
thanks
