Installation-wireguard-server-Ubuntu-18
anonim1
Post by anonim1 » Sat Mar 06, 2021 5:54 am
sudo apt update
sudo apt upgrade
sudo add-apt-repository ppa:wireguard/wireguard
sudo apt-get update
sudo apt-get install wireguard
sudo apt-get install mawk grep iproute2 qrencode
wget https://raw.githubusercontent.com/burgh ... y-wg-quick
nano /etc/sysctl.conf
#net.ipv4.ip_forward = 1 /////# clear///////
Ctrl+C
Ctrl+X
sysctl -p
chmod +x easy-wg-quick
./easy-wg-quick
cat wgclient_10.conf
cp wghub.conf /etc/wireguard/wghub.conf
systemctl enable wg-quick@wghub
systemctl start wg-quick@wghub
wg show
adding new profiles///////////////
./easy-wg-quick profile_name
systemctl restart wg-quick@wghub
skip line 2 do not wgclient_10.conf in the root folder
WinSCP wgclient_10.conf https://winscp.net/eng/download.php
https://www.wireguard.com/install/
https://www.chiark.greenend.org.uk/~sgt ... atest.html PuTTY
change the port to come up with your own
